04-13-2016 20:35
04-13-2016 20:35
Best Answer04-14-2016 01:38
04-14-2016 01:38
Best Answer04-14-2016 02:44
04-14-2016 02:44
Thanks - yes indeed in says Fitbit Notifications-Notifications are running.
Can I try anything else?
Best Answer04-14-2016 17:19
04-14-2016 17:19
The Fitbit app is at least running in the background?
Best Answer04-15-2016 00:21
04-15-2016 00:21
05-21-2016 14:26
05-21-2016 14:26
Best Answer07-07-2017 12:39
07-07-2017 12:39
Hi will my fitbit blaze work with my power 2 on android 7.It arrives tomorrow
Best Answer07-09-2017 09:13
07-09-2017 09:13
Hello @pf2303, is your phone been tested as being compatable?
Remember even if it isnt, that doesnt mean that it won't work.
Best Answer07-09-2017 10:13
07-09-2017 10:13
Thanks for your reply.
I received my Ulefone Power 2 and it is fully compatible with my Blaze.
It wasn't mentioned in the compatibility section but all works well. Even better than my old LG Stylus.
