02-25-2016 18:24
02-25-2016 18:24
I seem to always have this problem and I'm beginning to wonder if it's an Android issue cuz my SO doesn't have this problem with his iPhone. In the setting on the Blaze, I have an option for Bluetooth Classic and it's always "off". I can choose "pair" but then what?? Nothing happens. So I get no text notifications or music control. It does pair with the app on the phone for stats though. Anyone???
06-24-2017 11:56
06-24-2017 11:56
How long should the original pairing take. I just took it out of the box and it has been pairing for 35 minutes????
06-24-2017 12:49 - edited 06-24-2017 15:39
I found i have to accept it on the tracker first, then the phone.
07-04-2017 10:16
07-04-2017 10:16
This did not work for me. My android recognizes the blaze but the blaze is unpairable. never got the codes. I am upset that I paid a good amount of money for the Blaze and it cannot do something as simple as pair with my phone when the less costly Fitbit Charge HR was no problem. Thinking I need to be looking at a Garmin next after this Fitbit runs it lifecycle. If it is true to the half dozen other fitbit devices I have had it will only last 2 years tops.
07-04-2017 20:57
07-04-2017 20:57
@kbhetter, are you refferring to the Blqze Classic which this thread is about, or the Blaze? Only the Blaze Classic is able to be paired the way your trying.
Did you receive tye error "Rejected by Blaze"
08-07-2017 10:08
08-07-2017 10:08
Hi all,
classic problem,
cannot get notifications on my Blaze, phone is an S8.The phone says Fitbit notifications are running. I had 2 options to pair to Blaze and Blaze (Classic). Pairing is rejected by the Fitbit using Blaze, but will pair to Blaze Classic. Everything syncs to the phone, I just cannot get any email, message or. phone notifications.
Have I missed anything?
Any help is gratefully received.
08-07-2017 12:00
08-07-2017 12:00
08-07-2017 12:33
08-07-2017 12:33
I have tried all that, reset both devices, paired and unpaired Classic in case it was interfering with the LE Bluetooth. I have unpaired and 'forgotten ' all other Bluetooth devices. Still nothing.
08-10-2017 21:27 - edited 08-10-2017 23:14
Ok folks I found at least one problem and that is that the latest app update is broken when it comes to the Blaze. I received my 3rd replacement device and all of them did the same thing. Time would be off by over an hour and I could not change the clock face besides the fact that it failed all sync's and the two replacement units would not update from my moto x pure edition. I could use a samsung tablet to push the system update but it would not sync with the tablet. So I downloaded older versions 2.42, 2.50 and 2.52 all of which fixed every problem. I tried one of them with my wife's phone which was running an older official play store version and it worked and fixed the time and syncing. With in an hour it updated to 2.55 and it no longer syncs. The time has stayed correct as the App can't sync to screw it up.Fitbit App Version 2.55
08-10-2017 21:28 - edited 08-10-2017 23:15
removed and edited previous.
08-10-2017 22:03 - edited 08-10-2017 23:16
Same removing redundant post as I can't delete it.
08-10-2017 23:20
08-10-2017 23:20
After 30 min on the phone with FitBit US, they admitted that there are some syncing issues with SOME S8 units. I have the email if anyone wants it.
08-11-2017 14:24
08-11-2017 14:24
It's not just Samsung units. I have a Motorola that worked for over a year and then when the August 9th update came out syncing stopped. I have one replacement unit sent so far, but again it's the software, so maybe if they get this fixed it will just be a spare.
08-11-2017 15:53
08-11-2017 15:53
08-11-2017 15:53
08-11-2017 15:53
08-11-2017 19:02
08-11-2017 19:02
Is this tyread still about the Classic bluetooth, which has nothing to do with the ability to sync the tracker, or has this thread been hijacked!
08-11-2017 19:40
08-11-2017 19:40
08-11-2017 19:40
08-11-2017 19:40
08-23-2017 09:09
08-23-2017 09:09
Same here. I have an S8+ and the everything syncs except for sms, emails, etc notifications. its never worked for me. just got the blaze a couple of days ago. controlling music works.
09-03-2017 05:24
09-03-2017 05:24
I select Bluetooth pair on my blaze. Then on my Android device search for available Bluetooth devices. The blas(classic) populates. When I select it it registers as "pairing" but never gives any pin on the blaze or phone. My phone just says "incorrect pin or passcode"
I've restarted the blaze by holding the left and bottom button twice.
I've turned my phone off and restarted it as well.
09-19-2017 08:12
09-19-2017 08:12
Thank you BinarySoup! It seems that 2.52 is the latest version that still works on Android. I was able to rev back to that version and while I still can't seem to get the Blaze (Classic) to pair to Bluetooth, the app now syncs, I can change time zones and the clock face changes as well.
Hopefully Fitbit actually looks at this forum and realized they broke the syncing and still haven't fixed it.
