Hello @PColeman welcome to the Blaze family! 😉 Are you still having trouble setting up your tracker? If you're receiving an "Incorrect Pin or Password" error, chances are you're trying to set up your tracker using Bluetooth settings instead of the Fitbit app. Please try setting up your tracker as instructed here.
Let me know if this helps! ![]()
It is health that is real wealth and not pieces of silver and gold! Share your story!
I'm trying to pair my Fitbit blaze so it can control music but it keeps saying the passcode isnt right when It never even gave me one! Ugh I just got this and I really want to control my music with my blaze
Best AnswerWhat type of device are you trying to pair the Bluetooth Classic to,.
Best AnswerDroid turbo 2. It shows the blaze (classic) in my Bluetooth but gives me a error message saying unable to pair due to a wrong passcode
Best AnswerYou need to accept the pin in the Blaze Classic first, then the phone.
But you say it doesn't show up on the Blaze.
Have you tried a restart of the Blaze yet? Hold both the Left and lower Right buttons in.
Best AnswerI am having a similar issue. I had to get a new phone. I synced the new phone with the FitBit. All my progress is tracked as it should be. I am unable connect to Bluetooth for my notifications and music. When I go to bluetooth on my phone it finds my Blaze (classic), when I hit pair I get the incorrect passcode or pin error message?
Best AnswerDid you ever find an answer to your question? I have a new phone and I have the SAME question.
Best Answer@MoparGirl what phone do you have.
If the tracker is syncing then the notification channel is working, it uses the BTLE that sync uses.
On ios the standard Bluetooth is not used at all.
Best AnswerExact same issue for me. New Blaze device and a Droid Turbo 2. Everything works on the app and device through the regular app set-up connection with the exception of music control. The app explains what to do to connect with Blaze(Classic) but when I try I get the error that everyone else hear reports.
I have tried to remove the Blaze from the app and start from scratch with Blaze(Classic) only and it never works. The fitbit app always connects in the non Classic connection.
Would really like to control the music from the watch. Its a pain to have to pull out my phone while running.
Best AnswerThere are two issues mentioned above.
Issue one tracker wont display pin
Different issue number two, phone rejects setting up.
When the pin is shown on both the tracker and the phone, press the ok first on the tracker, then on the phone.
As for the pin not showing up on the tracker, this makes no sense to me (ive even connecte the Blaze to my Kindle). It connects to the phone as a standard input controller, nothing really different here.
Best Answer@princesstissue "not a go" doesn't give much info.
Where you able to pair the blaze classic.?
Best AnswerYea, I did. I am using Pandora so I opened it first. I wasnt doing that before. Then I went to pair the classic. It popped a code up then after I did that on my Fitbit.
Best AnswerI have to approve on the tracker first, then the phone.
After Pandora is playing what do go get on the tracker.
