01-28-2017 04:45
01-28-2017 04:45
Have been connected to Fitbit blaze for a week (android,) all.if a sudden its disconnected and now phone saying blaze rejecting connection.....help!!
Best Answer01-28-2017 07:24
01-28-2017 07:24
Did you recently install and Android update/security patch? Has happened to me since doing that. Rebooting the phone usually fixes it.
Best Answer01-28-2017 08:56
01-28-2017 08:56
@Chelpoole, is your tracker not syncing, a bond is not needed for this, or notifacations not be8ng received, a bond is needed.
The rejection message is most commonly seen when trying to do the impossible bonding of the tracker through the Bluetooth settings screen. This bonding must be done through the app, as is automatically done through a sync.
If your fitbit app is not syncing, or notifacations or not working, then this must be troubleshot.
I do agree the first place to start is a restart of the phone, still no, restart the tracker, not yet working, go into the phones Bluetooth settings and remove the bond to the tracker.
