01-08-2018
19:51
06:02
FerdinandFitbit
01-08-2018
19:51
06:02
FerdinandFitbit
I have used a Polar watch with chest strap for 4 years..450 calories burned on avg..in boot camp classes for 1 hr..With the Blaze I only burn 300 calories for the same class..Someone explain..Which is right ??
06:02
09:23
01-11-2018
06:02
09:23
Hey there @GSHoff. Great to see you in the Fitbit Community Forums! 🙂
Heart rate is closely related when it comes to calories tracking and heart rate accuracy accuracy is affected by personal physiology, location of wear, and type of movement. Please take a look at the following tips that should help making your heart rate readings more accurate.
When you’re not exercising, wear your device a finger’s width below your wrist bone. Fitbit’s PurePulse heart-rate tracking system is designed to be most accurate when the device is worn on the top of your wrist.
For improved heart-rate accuracy keep these tips in mind:
Hope this helps and if you're still having problems with this, let me know!
