01-19-2023
05:25
06:03
01-19-2023
05:25
06:03
My fitbit blaze battery died out and i want to replace the battery, can anyone suggest the process in India
Best AnswerHi @Naveen_IN you would need to find a place that sells a battery because Fitbit doesn't do or suggest replacement ones. You'd need a steady hand, good eye and tiny tools, if you feel comfortable doing it. You'll need to search online to find a company that sells the battery and there are probably instructions on You Tube. Might end up costing you more than purchasing another Fitbit.
