02-28-2016 08:25
02-28-2016 08:25
03-08-2016 19:40
03-08-2016 19:40
I have an ATT Note 5. I'm sure they haven't updated the list yet, but all features work on it. No reason it shouldn't be listed.
A tweak to know is the default messaging app (ATT Messages) will only show a notification of the text message but not the message content. If you download Google Messenger and make it default (and use it), the Blaze will show the notification alert and the text message as well. And, Google Messenger uses less battery.
The phone call notification works...although you can only answer the call with Blaze connected to iPhone.
Calendar notifications work using the default Note 5 Samsung Calendar.
Music app...I don't know. It requires a Classical Bluetooth connect and for me, easier to navigate on the phone anyway. Didn't want to drain more battery.
Syncing with the FB Android app has been flawless. No issues.
Hope this helps.
02-28-2016 09:43
02-28-2016 09:43
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
02-29-2016 19:20
02-29-2016 19:20
02-29-2016 19:26
02-29-2016 19:26
02-29-2016 20:31
02-29-2016 20:31
02-29-2016 20:37
02-29-2016 20:37
02-29-2016 21:28
02-29-2016 21:28
03-01-2016 02:07 - edited 07-19-2016 18:23
@Lyly712 do you want to connect the bt for music control?
On the Blaze you turn the classic Bluetooth to pair. Note go to the phones BT screen and pastor it the same way ypu wpuld pair a speaker.
03-01-2016 11:39
03-01-2016 11:39
I finally got the notifications to work on my Note 5. I completely uninstalled the fitbit app and the unpaired the Blaze then reinstalled and reconnected the app and the Blaze and they are working for now even though it shows all texts 2 times. We will see if it lasts.
03-01-2016 11:46
03-01-2016 11:46
03-06-2016 05:50
03-06-2016 05:50
03-08-2016 18:34
03-08-2016 18:34
03-08-2016 19:40
03-08-2016 19:40
Hope this helps.
03-08-2016 20:27
03-08-2016 20:27
03-12-2016 09:57
03-12-2016 09:57
Glad it helped! Hopefully will help others as well.
05-14-2016 20:00
05-14-2016 20:00
05-14-2016 20:06
05-14-2016 20:06
05-18-2016 05:58
05-18-2016 05:58
I realize (now) that the Note 5 is not compatible with the Blaze (which is frankly ridiculous), but all but one feature is working--notifications. I see that some people have got theirs working, and I have read some tips, but I still cannot get notifications to work. I have a USCellular Note 5. Please help!
05-18-2016 06:19
05-18-2016 06:19
When I set up the Blaze, I chose Note 4 since Note 5 was not an option. Perhaps there is a better choice that will allow for notifications . . .
06-21-2016 13:24
06-21-2016 13:24
I have a Note 5 and I just bought the Blaze last night. I was about to return it because I could not get the notifications either then I found out it was not compatable. I went to the Play Store and Downloaded Fit Notifications and everything is working now.. Caller ID, and texts.. yaaaaa.
