10-22-2017
18:29
06:48
AlejandraFitbit
10-22-2017
18:29
06:48
AlejandraFitbit
I don't know, but since this last update I've had issues with my Blaze. Anyone else have issues? Black screen? Battery draining fast? Can't swipe side to side?
10-22-2017 19:35
10-22-2017 19:35
My screen was flashing colors but I closed the app, restarted the tracker, and synced, seems to be fixed.
10-23-2017 06:50
10-23-2017 06:50
It's great to see you around @bballmomof2boys and @IcebergShorty thanks for stopping by.
Regarding the swipe and screen issues, I recommend restarting your Blaze. Also can you please tell me if your tracker is illuminating while being in the cradle?
About the battery, take a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome.
10-23-2017 11:18 - edited 10-23-2017 13:27
Thank you, I've done all the above without luck. Restarted it dozens of times. Cleaned the ports, charged it multiple times no luck. I am also getting a replacement in hopes I don't have issues with it as I know it will be a refurbished one.
10-23-2017 13:30
10-23-2017 13:30
No it is not illuminating while in the cradle. It's been in the cradle all day, forgot to remove when I left for work. Tried to power on, logo came on, and turned off again.
10-30-2017 06:07
10-30-2017 06:07
Thanks for the update @bballmomof2boys. I would like to know if you have contacted our support team? Have they offered you with a solution for this?
See you around.
10-30-2017 06:34
10-30-2017 06:34
Yes I did. I now have a new pebble.
10-30-2017 06:36
10-30-2017 06:36
Those are great news @bballmomof2boys, I am glad to hear that you received a replacement pebble. If you need anything else, do not hesitate in posting it.
Happy stepping!
