11-28-2017 08:41
11-28-2017 08:41
I just got my Blaze yesterday and love it.. but.. i can't read my text messages.. they show up but ot just says 'new message'. Nothing happens when I tap it. Pretty sure its probably a setting on my phone but dont know where to look.. I have a Samsung S7
Thanks
08-04-2019 21:59
08-04-2019 21:59
Hello,
Any update on a solution for the fact that all I see is "view message" on my blaze verses the message?
I was once able to see the message now that is now happening
08-07-2019 09:47
08-07-2019 09:47
Welcome to the Community @SunsetRunner. I appreciate the details shared.
I would like you to confirm that you've tried the procedure mentioned above and if you're still experiencing this. I can confirm that Fitbit is aware of it and working on a resolution.
08-07-2019 11:08
08-07-2019 11:08
08-07-2019 11:09
08-07-2019 11:09
Hello,
Yes, I have tried the procedure mentioned and it still doesn't work. The odd part is the watch and messages worked until approximately 2 weeks ago, at which point it wasn't working.
08-08-2019 14:28
08-08-2019 14:28
Thanks for getting back @SunsetRunner. I appreciate that you mentioned you've had your Fitbit Blaze for more than a year.
Sorry to hear that the troubleshooting mentioned above didn't work. Fitbit is aware of it and working to identify a resolution as quickly as possible.
08-16-2019 05:16
08-16-2019 05:16
Same thing has happened to mine. Had mine since 2016 and just recently started not showing my whole messages. I've done everything as listed above. Wish Fitbit would get this fixed. It is the main thing I use my blaze for.
08-16-2019 07:02
08-16-2019 07:02
I worked with Fitbit for days and no changes. the last response was, in short, a sorry and they do not have a solution at this time the issue is not common and hopefully it will fixed with the next update and to keep my Fitbit updated.
To be honest my Fitbit is always updated is always updated and I was not happy with the response. Not only did I feel like they couldn't help bit that they gave up. Oh well 😒
08-20-2019 16:52
08-20-2019 16:52
I have also been having this issue, any time I get a text, it says "view messages". This had been happening for about 2 weeks and I've had my blaze for almost 2 years.
09-24-2019 19:45
09-24-2019 19:45
Fitbit has changed the code on the developer end to get blaze users to update their discontinued product. This was done during an update. Save your money! Fitbit lite is currently the cheapest equivalent. Use caution as they have the ability to continue to do this on any of their products.
09-25-2019 09:40
09-25-2019 09:40
When did they change this code @Happy-g this thread was started while the Blaze was the premiere tracker.
