Change water display units on Dashboard
ANSWERED
Hi I am trying to change the display of my dashboard for the Fitbit app for my water consumption. I know how to change it to oz when I enter my consumption but then it always shows in ml for tracking. (40 oz entered, and then shows 1183 ml in the dashboard) is there a way to make my dashboard display in oz as well?
Thank you!
2 BEST ANSWERS
Accepted Solutions
@zhertz, say did you make your change under your account? If not, login to your Fitbit account and go to advance setting then go to units. Under units go to water once there you can make your setting for oz or milliliters. Hope this helps
@zhertz, I'm using the iPhone 6plus. I downloaded the app to my phone. The Fitbit app version I have is 2.26.1(572). So when I'm using my phone I can login to my Fitbit app. On the bottom row you will see some tabs. Starting on the left you will see dashboard, challenges, +,friends and account. When you go to your account you will be able to make you change for your setting.
4 REPLIES 4
Thanks. I realized I had to do it through the website. I was trying to find the settings you were referring to in the app and it isn't there. Thank you aclobos
Hello @Z_Hertz welcome to the Fitbit Community! I'm glad you were able to change the settings on your app. @Aclobos thanks for sharing how to do it on both platforms! 🙂
If you have any questions, lets me know! 🙂
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
