03-11-2016 21:36
03-11-2016 21:36
Best Answer05-25-2017 16:22
05-25-2017 16:22
What U also need to do, is to make sure that your android is connected with your fitbit through Bluetooth.
06-19-2017 16:10
06-19-2017 16:10
None of this works with my Windows 10 laptop. Won't even update. Took the first one back, thinking it was broken. Second one, tried syncing with my wife's iPhone and got it initially setup... This is my 3rd FitBit in 3 years. There won't be a fourth unless it's a gift, like this one.
06-30-2017 16:01
06-30-2017 16:01
Been tapping the face all day and the clock face will not change. I selected the face I wanted on Fitbit.com and the face will still not change. Please help, I have trouble reading the face that came on my new Blaze!
Best Answer06-30-2017 16:16
06-30-2017 16:16
Best Answer06-30-2017 17:15
06-30-2017 17:15
You got what and thanks for what? I want to change the clock face and I can’t see where your post aided me in any way?
Best Answer06-30-2017 17:27
06-30-2017 17:27
Best Answer06-30-2017 19:11
06-30-2017 19:11
Best Answer06-30-2017 20:06
06-30-2017 20:06
@coachmcguire when you change the clock face on the Web your just changing a setting in your account. Now you have to transfer this setting to your Blaze by doing a sync. This will then download and install the new face.
Best Answer07-01-2017 05:02
07-01-2017 05:02
Best Answer09-23-2017 16:42
09-23-2017 16:42
I did that. When I scroll there is not s clock line
Best Answer09-23-2017 16:44
09-23-2017 16:44
I scrolled and no clock display
Best Answer12-13-2017 04:16
12-13-2017 04:16
Can u pls attach any video for changing the clock face on the device itself. Coz my phone is not listed in Fitbit n it's not syncing.
12-13-2017 07:56
12-13-2017 07:56
@Ravi2589 how are you syncing your tracker? Through your web based dashboard, tap the icon of your tracker, tap the clock face setting, pick the wanted face, sync the tracker.
@Barbsra I'm not following you. Are you on the web or app while you are scrolling. The above instructions work on the web and app.
Best Answer01-05-2018 18:30
01-05-2018 18:30
I’ve tap it twice and nothing happens
Best Answer08-02-2018 08:43
08-02-2018 08:43
First go to app. Tap picture of Blaze in upper left corner. Then pick clock face. Choose face, then sync now. You should get face you want then.
Best Answer02-25-2021 13:35
02-25-2021 13:35
Hi Wendy,
I am looking under the settings for my charge 4. There is nothing that says clockface. I changed the face once before but now I want to change the brightness. I cannot see the display outside. I have looked at the manual that says tap clock faces. But there is nothing to tap. It used to be there but now it is gone.
Please help.
Thanks Lezliedawn
Best Answer02-25-2021 14:31
02-25-2021 14:31
Hi @lezliedawn on page 27 of the owners manual, on the Blaze swipe to settings, tap and swipe up to get to Brightness.
Clocks are changed from inside The Fitbit app
Best Answer02-26-2021 08:57
02-26-2021 08:57
