Charge time from dead to full battery for Blaze?
ANSWERED
How long does it take for the Blaze to fully charge?
29 REPLIES 29
E was also dead when I got it. Kinda disappointed, as we picked it up on our way for a hike, but now I can't even complete the set up till it's charged up. I did not have this problem with my flex.
@Raych32, while it is in its charger and charging, continue with the setup. The app will see that it is charging and nit complain and finish the uodate process.
Then you may add the battery level menu, and be able to decide if there is enough charge to take off.on the hike.
I figured that would wprk, however, it didn't, still says "battery too low
to continue"
I figured that would work, but it still says "battery too low to continue." I think it's because I have to download some firmware, but it won't let me get past it (and download later) to finish set up.
@Raych32 when the tracker is connected to its charger, did you feel a vibration?
It should vibrate when connecting and disconnecting.
No, just displays the logo and "fitbit.com/setup". I know it's charging
though, I can see on the app. It's updating now, says it could take up to
10 mins, but it's been longer than 10 mins since it started. It's just
super disappointing, because we wanted to go on a hike, but I won't be able
to use it, as I can't set it up till after this update.
I can. charged my Blazer in 15 mins full charge !
Same here, arrived dead - I wondered why it didn't say charge then attempt set-up
charge time from dead to full battery for blaze
It doesn't really take that long to charge up, like under an hour I would say. Sometimes I charge it in the car on my way to work, and I get like half a battery in 20 mins or so.
