12-09-2016
15:54
17:01
DavideFitbit
12-09-2016
15:54
17:01
DavideFitbit
I had Qustion for you ?
On Monday on charged my blaze over night ? i had all day at 4:30pm on tuedsday went low bettery?Has that happed to anyboby if show tell what you did i the same thing
thank you
12-09-2016 19:56
12-09-2016 19:56
The Blaze should have 5-7 days of battery life under normal use. One possibilit y of fixing this is to restart your unit - follow the instructions here. Suggest you restart at least twice and see if this clears up the issue. If it does not then contact the help folks to see if there is anything else you can try or maybe get a replacement.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
12-09-2016 22:05
12-09-2016 22:05
12-10-2016 12:34
