02-12-2017 01:36
02-12-2017 01:36
Hi I bought my Blaze Fitbit yesterday and started setup and charge.
I cannot seem to see the battery image when I charge it. I connected it to a wall USB overnight !
I cannot see any function on the screen.
02-12-2017 01:38
02-12-2017 01:38
Hello @AWM, do you see anything on the screen? Like the nessage http://www.fitbit.com/setup?
02-12-2017 01:57
02-12-2017 01:57
02-12-2017 02:17
02-12-2017 02:17
I see Fitbit.com/setup not the battery charging
02-12-2017 02:17
02-12-2017 02:17
Thats what i thought, it will not show or do anything untill it knows what account it is attached to. Right now it is waiting to be set it up.
Did tge tracker vibrate when plugged into its charger? That is how you kniw tyat it is charging.
Go to the setup address through the device you want to use, this will oromot you to download the software for this device. Now run this software, follow the prompts. You want to choise the i have an account, then log in to your fitbit account.
You won't know if tye battery needs charging, until the setup procedure says it does, it might not have needed to be charged.
02-12-2017 04:43
02-12-2017 04:43
02-12-2017 07:08
02-12-2017 07:08
Hi Rich
A bit of good news...I can now see it synching and battery icon showing on low. I must be doing something right. I will leave battery on charge for some time?
