With so many **ahem** faces to choose from and many need purchased, there needs to be a way to keep track of the ones you like and more so purchased. When a clock face is purchased, then you later change it to something else, the purchased face is lost among the hundreds of other clock faces. There needs to be a favorites and a purchased list. Sounds simple enough right?
If you are buying a lot of clock faces its up to you to keep track. Not Fitbit.
I have only bought 2 and I have a spreadsheet with all the info I need in case I change a device
Wendy | CA | Moto G6 Android
