03-20-2016 23:38
03-20-2016 23:38
Best Answer03-21-2016 00:55
03-21-2016 00:55
According to the manual, to use the connected GPS feature you need to:
"1. If you’re going to use connected GPS with an Android device, make sure you’ve enabled call, text, or calendar notifications.
2. If you’re going to use connected GPS, make sure Bluetooth and GPS are both enabled on your phone."
This is from page 15 of the manual: https://staticcs.fitbit.com/content/assets/help/manuals/manual_blaze_en_US.pdf
What issue are you seeing when you don't have wifi enabled?
03-21-2016 00:19
03-21-2016 00:19
@Kat2812 wrote:
My fit bit blaze can only connect to the gps with WiFi is it possible to do it without WiFi
that's not a Blaze problem.
it's a smartphone problem.
but GPS is not related to wifi.
03-21-2016 00:55
03-21-2016 02:57
03-21-2016 02:57
Best Answer03-26-2016 09:40
03-26-2016 09:40
Hello @Kat2812 welcome to the Fitbit Community! 🙂 @Rich_Laue, @SteveH and @SunsetRunner It's great to see you around! 🙂 @Kat2812 I would suggest to visit this thread for more information about Connected GPS
Thanks for stopping by! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
