01-30-2018
08:58
05:08
AlejandraFitbit
01-30-2018
08:58
05:08
AlejandraFitbit
Can someone help my Blaze is only a month old? I'm wandering if I’m going to have the same problems as my other Fitbit.
01-31-2018 02:44
01-31-2018 02:44
@Debs6941 have you cleaned the contacts with isopropyl alcohol.
01-31-2018 02:44
01-31-2018 05:12
01-31-2018 05:12
A warm welcome to the Community @Debs6941 and @Rich_Laue thanks for stopping by.
If you are having issues charging your Blaze, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome.
01-31-2018 06:00
01-31-2018 06:00
If the above doesn't work and if you have the cradle plugged into a USB port on your PC or Laptop then try plugging it into a different USB port in case there is an issue with the USB port itself. If you are using a wall adapter then try using your computer USB port instead. (I know it may seem silly, but it's worth a shot)
06-18-2018 13:12
06-18-2018 13:12
Thanks
