02-18-2018
20:31
04:20
AlejandraFitbit
02-18-2018
20:31
04:20
AlejandraFitbit
Fitbit syncs but dashboard says no device paired.
02-18-2018 22:12
02-18-2018 22:12
Is the Fitbit syncing to the same account that your logged into on the dashboard?
Which dashboard or you logged into? The app on the computer or phone, or the web based app, and through what device do you sync your tracker?
02-19-2018 04:27
02-19-2018 04:27
A warm welcome to the Community @Newuser27 and @Rich_Laue thanks for stopping by.
Do you have more than one Fitbit account? If you do, I recommend going to the Dashboard where your Blaze appears like paired and check the Fitbit email address in that account, then paired the tracker to the correct account by doing the following from your Fitbit app:
Let me know the outcome.
03-05-2018 07:07
03-05-2018 07:07
Thank you! That took care of it. Do you know how to delete the wrong profile so that this doesn't happen again?
03-05-2018 10:20
03-05-2018 10:20
@TheresaHealth you may either ignore the wrong profile or contact.fitbit.com and ask them to delete it.
03-07-2018 03:06
03-07-2018 03:06
Hey @TheresaHealth, welcome to the Forums and @Rich_Laue thanks for stopping by.
I am glad to hear that the instructions provided helped you. Now regarding your question, I recommend keeping an eye on your inbox for further assistance.
See you around.
