07-23-2017
18:12
04:47
AlejandraFitbit
07-23-2017
18:12
04:47
AlejandraFitbit
I've had my Fitbit Blaze for a little over 3 months just two weeks ago I was out in the rain with a sweater and Fitbit on underneath, I noticed that the battery was acting up after this by showing different percentages on the cell phone app and blaze, it would show the battery symbol blinking showing its low when really i had just charged it a few days prior. Now it says the battery level is "Empty" on the Fitbit app, I've already tried resetting it and it still continues, what should I do?
07-23-2017 20:09
07-23-2017 20:09
Welcome to the forums @arch93
Sounds like water damage. Did you try putting the Blaze into a dry bowl of rice before charging it?
If you're within the one year warranty and it was purchased from an authorized retailer, contact customer support at this link - click
There is a phone number for the USA, an online chat option and web based email for those out of the area.
Keep us informed.
07-24-2017 04:46
07-24-2017 04:46
07-24-2017 04:50
07-24-2017 04:50
A warm welcome to the Community @arch93 and @Odyssey13 thanks for stopping by.
Fitbit tracker are not waterproof, just the Flex 2. But regarding your Blaze, as recommended, place your tracker in a bowl with rice for 24 - 48 hours and then restart it. If you keep having battery inconveniences, follow the instructions provided in this post.
Let me know the outcome.
07-24-2017 04:54
07-24-2017 04:54
