09-30-2017
13:12
12:17
FerdinandFitbit
09-30-2017
13:12
12:17
FerdinandFitbit
Earlier this week I tried to check my steps while I was at work. But whenever I swiped left on my Blaze nothing will happen typically I get different screens one that shows me all my stats for the day another one that does little breathing exercises one that sets a timer and various other functions. Has anyone else had this trouble? And how do I fix it so I can have full access to my Blaze screen again?
12:16
08:21
10-02-2017
12:16
08:21
Hi there @pretzeltrack112. Great to see you in the Community Forums! 🙂
I'm sorry you're having problems to access the screens on your Blaze. Have you already tried restarting it? If not, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Also, you can try changing your clock face. For this, go into the app, tap on the icon of your Blaze at the top of the dashboard and then scroll down to "Clock Faces". Here change to the clock face you want, sync your tracker and once the changes have been made, see if you're able to swipe to the other screens.
Hope this helps. Let me know if you need anything else!
