03-09-2016
17:04
19:14
DavideFitbit
03-09-2016
17:04
19:14
DavideFitbit
How close does your iPhone need to be to the Blaze in order to get texts or calls?
Best Answer03-09-2016 17:45
03-09-2016 17:45
It should be the same proximity needed to sync, so 10 or 15 feet easily. I haven't played around with it at all, so I don't have a good feel for the maximum distance.
MakMak | Community Council
03-10-2016 12:36
03-10-2016 12:36
Hey hey @Wriggles15 it's great to see you around! As per official documentation, your tracker should be withing 20 feet (6 meters) to receive notifications.
Remember that the new Fitbit Blaze also features calendar notifications, give them a try! If you want to learn more about your tracker, check out the product manual.
Keep the stepping up! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
