04-04-2016
04:59
18:29
DavideFitbit
04-04-2016
04:59
18:29
DavideFitbit
Do I keep blootooth on all the time on iPhone . Bought Fitbit Blaze
04-04-2016
05:09
18:30
DavideFitbit
04-04-2016
05:09
18:30
DavideFitbit
Not needed.
only if you want All Day Sync, which is a battery draining.
you can enable Bluetooth only when you want sync.
04-04-2016 05:40
04-04-2016 05:40
Keeping Bluetooth on all the time shoudl not drain that battery though, unless your conencted items are drawing power from it......you can turn off "All day sync" in the Fitbit app and it really does not communicate with Bluetooth until you open the app.
