Doesn't come on when i turn my wrist
Blaze doesn't come on when I turn my wrist. do i need to fix in settings? also, In regards to my previous post, is the reason i did not get the text was that I was asleep? b/c I just receive a text on my blaze and im in my study which is next to my bedroom. just curious!
Moderator edit: subject updated for clarity
1 REPLY 1
@softballgirl18  Make sure you have "Quick View" enabled on the Blaze.  On your Blaze, scroll to "settings" and under quick view, make sure it is on.
Hope that helps!
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
