02-15-2018
12:46
14:52
AlessFitbit
02-15-2018
12:46
14:52
AlessFitbit
Fitbit Update 2/16/18 -- Since our engineering team confirmed this issue was resolved yesterday 2/15, we're going to close this thread from further discussion. Thanks to everyone that reported this here on the Forums. We appreciate you taking action and glad there was a speedy resolution.
See you around the boards!
Update 2/15/18 (Part 2) -- Our engineers have reported that the issue should now be fixed. I recommend giving your Blaze a quick restart and then try changing to the Zone clock face again. Let me know how it goes!
Update 2/15/18 -- Thanks to all of you who have reported your experience trying to change to Zone Clock face on Blaze. I've merged all relevant threads here to keep things tidy.
At this time, I recommend avoiding the Zone clock face until we remedy the issue. For those of you who are seeing the 'X' on your Blaze display after attempting to change to the Zone clock face, please do the following to get back to a working clock face:
I've flagged this issue to our engineering team who will investigate. When I hear something new, I'll update you with the latest. I appreciate your patience and please update the thread if the above workaround doesn't get rid of the X on the display.
02-15-2018 00:35
02-15-2018 00:35
Yes I had the same thing, it switched back to original, without me choosing. When I tried to set it back to zone it failed, as other people have said I can select other faces.
@LauraHodgewrote:My Fitbit blaze is always set on zone and all the sudden it stopped working and switched to the original clock face. So I went under settings to re-apply zone and it kept saying clockface error please pick another clockface, which is highly annoying because I don’t really like any of the other ones that much. Any ideas on why it stopped or how to fix it?
Thanks
Best Answer02-15-2018 00:48
02-15-2018 00:48
Yes my Zone clock face also disappeared and randomly reset itself to Classic and no matter what I do to troubleshoot - reboot, set up new blaze etc - it appears to be gone.
There is randomly an intermittent new setting which is called Bluetooth Classic which presumably allows you to set up Classic from the tracker.
It would be good for Fitbit to get involved with sorting this out - there seem to be a lot of people with the same problem?
02-15-2018 00:59
02-15-2018 00:59
Me too. I did have the zone Face and it defaulted to the original. Hope fitbit fix it soon and while they are at it- how about some new faces???
02-15-2018 01:11
02-15-2018 01:11
Yes. Mine switched to "Original" overnight and can't get it back.
Also noticed that fitbit didn't give details on sleep tracker last night, just basic results despite sleeping more than a nap !
02-15-2018 01:15
02-15-2018 01:15
I’ve just reported it to Fitbit so fingers crossed.
02-15-2018 02:07
02-15-2018 02:07
Dear Community
As a regular runner I have always used Zone clock face so that i can monitor HR at a glance.
Today for no apparent reason my clock face changed to Original.
When I try to reset to Zone, I get a Red Cross and then an Error Message on my tracker.
When I force sync the watch face and dashboard automatically change back to Original.
I have logged out on my iPhone and signed back in again, and also rebooted tracker without any luck.
Any suggestions?
Blaze Runner
02-15-2018 02:50
02-15-2018 02:50
Same thing happened to me yesterday. I need the "zone"!
02-15-2018 03:03
02-15-2018 03:03
Same here. Woke up to original clock face this morning and won’t reset. Love the zone and HAVE to have it
02-15-2018 03:05
02-15-2018 03:05
Same here with me too. Unable to set Zone as my clock face.
02-15-2018 03:44
02-15-2018 03:44
It's great to see you around @Kpescinski.
Thanks for troubleshooting this by yourself. Could you please provide me with a picture of your tracker's display by following the instructions provided in this post?
Hope to hear from you soon. ![]()
Best Answer02-15-2018 05:11
02-15-2018 05:11
I like the Zone click face. I found a big red X this morning - clock face failed, pick another face.
This, combined with the Sleep and gross inaccuracies, makes me question the watch choice. Right now the great battery life is the single plus.
02-15-2018 05:17
02-15-2018 05:17
Mine is doing the same thing, not a happy camper this morniong.
02-15-2018 05:27 - edited 02-15-2018 07:59
I reported this to tech...
02-15-2018 05:29
02-15-2018 05:29
Not sure why the random emojis are there. Looks normal when I paste it?
Best Answer02-15-2018 05:32 - edited 02-15-2018 15:43
02-15-2018 05:37
02-15-2018 05:37
I am also having this issue. Using the zone since I've had my Blaze since 2016. I love it. I am thinking its an app issue because I've had problems since the last update.
Bonnie - emojis showed up because a colon : and and o makes this face 😮 i believe.
Best Answer02-15-2018 05:42
02-15-2018 05:42
Keep getting original clock face won’t go to space which always had
Best Answer02-15-2018 05:56 - edited 02-15-2018 05:58
Hi have had the same problem, loosing zone and sleep reverting back to the old style of recording. My wife has a Charge2 hers has done the same with the sleep pattern. I had a quick look at the charge2 community and people there are complaining. This is definitely not user error, sleeping wrong or device failure, this is something central or software update related.
My firmware version is 17.8.402.1
Best Answer02-15-2018 06:10 - edited 02-15-2018 08:11
So do I understand from your interaction that this issue may or may not eventually be fixed, and that the option they are suggesting is to buy a new fitbit???
Best Answer02-15-2018 06:25
02-15-2018 06:25
I'e tried everything from restarting my phone to reconncting to my blaze. I cant get my zone clock face back. My clock face changed automacticly to some ugly one. so mad. Fit bit please fix this bug soon.
