04-13-2017 21:13
04-13-2017 21:13
I am unable to scroll over to any other screen. To view stats, no logging workouts, etc... What I currently have is a very expensive digital watch. I'm frustrated because I could have went to a discount store and purchased a digital watch that shows the time if this is what I wanted. Anyone else having this problem?
Best Answer04-13-2017 21:16
04-13-2017 21:16
Welcome to the forums!
Are you using the buttons? First thing to check is remove it from the frame and see if it works. If it does then its not put in the frame correctly
If it does work:
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
Best Answer04-14-2017 19:16
04-14-2017 19:16
