05-02-2017 04:57
05-02-2017 04:57
Hi I woke up this morning and my fit bit battery was low, plugged it in to the charger when I got to work and it doesn't appear to be charging. Nothing is displayed no symbols to say its charging...When I press all three buttons it displays the Battery Symbol which is in the red, when the buttons are released it goes blank...
Any help appreciated
Thanks
Best Answer05-02-2017 06:09
05-02-2017 06:09
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
05-02-2017 06:09
Then Do a Restart
Best Answer06-10-2020 13:01
06-10-2020 13:01
I have the same problem...battery won't hold a charge in a Fitbit inspire hr...will charge to what it says is :hundred_points: and then die in an hour...contacts cleaned, hard reset x5... X8 soft resets and nothing...
