10-09-2016 12:14 - edited 10-09-2016 12:15
I have had my Blaze since June and in the last two days a full battery will drain within 3-4 hours. I have not changed any settings. Please advise. Thanks.
06-24-2017 17:50
06-24-2017 17:50
So, just an update. I did receive a new device. Crossing my fingers, but no problems so far. I activated it on Tuesday and finally charged it today.
06-25-2017 15:35
06-25-2017 15:35
I'm getting the same problems with the battery as you guys.
Only had my balze since Christmas gone. Had brilliant battery life (5 days) now it dies with no warning!
I have the added problem of a white static screen when going on charge! Looks completely gone!
Nothing had happened to the watch to cause damage & it's still syncing to my phone while In the white screen mode!
Help!!!
06-25-2017 18:59
06-25-2017 18:59
I am also having the same issue over the last 2 days with my Fitbit Blaze. Have had the device for about 3-4 months and it has consistently kept a charge for 3-4 days. Over the last two days it has drained a full battery in less than 10 hours each day. My device is synced to an iPhone.
07-09-2017 18:45
07-09-2017 18:45
Have my Fitbit Blaze less than one year until three days ago the charge lasted 2, 3 even 5 days. Now I only get 4 or 5 hours and it is completely drained. I have change the settings so I don't get notifications and other settings and it stills drains but it all worked before
08-30-2017 07:15
08-30-2017 07:15
I had a Galaxy S8 recently, over the following week my Blaze battery life went down to 1-2 days, uninstalled the Fitbit app and disconnected the bluetooth link from my phone so I'm just using my laptop for my Blaze - all back to normal, battery usage back to 5 days!
08-30-2017 07:16
08-30-2017 07:16
Same for me This problem started with me soon after getting my Galaxy S8. I've since uninstalled the fitbit app from my phone and my Blaze is holding a usual five day charge.
08-30-2017 07:17
08-30-2017 07:17
08-30-2017 08:47
08-30-2017 08:47
09-05-2017 09:06
09-05-2017 09:06
Same problem here. Loved my blaze, would get 4-5 day life out of it easily then it dropped to two and now less than 24 hours. It's become completely useless for continuous tracking which is what I did use it for.
This last week I've not tracked 90% of what I would have liked because it was in charge so much it just wouldn't be ready when I went out.
Im on android on an s8 & i've turned off:
Notifications
BT classic so no music control
Quick view
All day sync
Always connected
And have the screen brightness set to minimum.
The only thing left to turn off is hr which seeing as that's the main reason I got it is would defeat the point of having it.
Not happy
09-05-2017 09:56
09-05-2017 09:56
09-05-2017 10:05
09-05-2017 10:05
Cheers.
Unfortunately without the phone app it's pretty much useless to me. I only use my laptop for work (my way of keeping business and personal separate as I'm self employed).
Ironic really that after selecting fitbit over competitor devices partly on device reliability and the usability of the phone app it's now those two things in question.
Fingers crossed they pull their fingers out and sort out the issues.
09-05-2017 12:18
09-05-2017 12:18
I figured out my issue - the stopwatch on the choronograph face absolutely burns through the battery. If I forget to turn it off after a few hours, significant battery drain is noticeable.
09-20-2017 17:45
09-20-2017 17:45
did lower the brightness, change to auto and also to low but still draining my battery within a day and a bit
09-29-2017 02:14
09-29-2017 02:14
Some problem. I have my blaze for at list one year without any problem (4 to 5 days of battery) and suddenly the watch die in a few hours (5 to 6 hours, yesterday ).
09-29-2017 02:49
09-29-2017 02:49
09-29-2017 04:29
09-29-2017 04:29
I am having the same issue. I can't find a way to contact them except twitter??? What number did you call?
09-29-2017 05:29
09-29-2017 05:29
10-28-2017 01:09
10-28-2017 01:09
same issue. was fine last week, changed nothing, now draining in 12 hrs...
10-28-2017 05:55
10-28-2017 05:55
I changed the settings from 'all day sync' and now sync manually untill this issue is fixed. Battery is now back to lasting 4-5 days.
10-28-2017 06:19
10-28-2017 06:19
I did the same as mickpayton changing the settings and it work.
Manually sync it maybe 4 - 5 times a day
