Best AnswerWhen you scroll from the home screen to Exercise, then tap, then see the Run screen there is a gear in the lower lefthand corrner. When you tap the gear you have options to select, one of which is the Secondary Stat. One of those choices is Distance. Is that what you were looking for?
@Runnergirl16 wrote:
You my friend are awesome!! Thanks a million!!
Excellent! You're very welcome.
