06-26-2016 00:52
06-26-2016 00:52
Just bought a blaze to replace my Charge HR as my main everyday device (and so far loving it) BUT my biggest gripe is that the much promised 'merge' feature isn't working.
To elaborate, I wear my Blaze 24/7 except when I play squash, and at that point I change over to my Charge HR (smaller target). While the Charge HR will happily record my exercise, it will no longer record my heart rate during that period (basically during the time I most want it to). I confirmed while playing that it was registering on my device itself, yet when I synced with my iPhone 6s Plus it did not log the heart rate at all. I log each game to try and regulate my heart rate to cardio, and the device did read my heart rate during games and even showed the average post game, yet it does not show on my excercises.
Any fix for this. Am I doing something wrong?
Best Answer06-26-2016 21:44
06-26-2016 21:44
A couple off thoughts I have @FlyBoyJIt
Try a sync at the time of switching. Fitbit recommends this, I find it unnecessary.
Check the times in question on the web.. If things look good here then log out on the phone app, and back in.
This weekend I have switched between the Charge HR, blaze and Surge, with only one break in heart rate.. I fell asleep without a tracker on.
Best Answer06-26-2016 22:20
06-26-2016 22:20
You might also try restarting the HR in case there is a "bug" in it. Go to "Help" at the bottom of the page and then click onto the HR icon. One of the options will be instructions on how to restart the HR.
06-26-2016 22:51
06-27-2016 17:08
06-27-2016 17:08
Best Answer06-28-2016 02:49 - edited 06-28-2016 02:55
@FlyBoyJIt you have left me a little confused, to turn the Charge HR off is a multi step process and removes the unit from your account, requiring it to be setup as an additional device.
I don't worry about turning anything off, the screen and Heart rate or set to auto, when the tracker is off the arm the Heart Rate turns off automatically.
In any case have you done the restart of the Charge HR yet?. Many say to do it there times, it sometimes doesn't work at first.
You haven't mentioned if you ever see a heart rate while looking at the Charge HR?
Best Answer06-28-2016 20:14
06-28-2016 20:14
Sorry, I was on my phone so was not providing complete info. My 'steps' 😛 in detail.
Before Starting any excercise.
During Exercise
Play squash logging each game. I can confirm that I check the HR between games to ensure heart rate is being logged, and the the overview at the end is logging the average as well.
Post Game
Best Answer06-28-2016 20:33
06-28-2016 20:33
@FlyBoyJIt you say your heart on the Charge HR doesnt work? Have you cheked the device settings of the unit to make sure that the Heartrate is turned on?
Also has a restart been tried?
Best Answer06-28-2016 20:44
06-28-2016 20:44
It does work on the HR and it does show on screen while exercising. I have restarted multiple times with no change.
Best Answer06-30-2016 02:40
06-30-2016 12:18
06-30-2016 12:18
I would click the settings gear in the top right of this page, or go to help through the app. In both places you will find a link to contact Fitbit. Let them know what is happening.
They can see behind the scene.
You might also want to try wearing the Charge HR all day.
