06-05-2018
11:08
09:37
FerdinandFitbit
06-05-2018
11:08
09:37
FerdinandFitbit
My Blaze used to last the advertised 5+ days on a single charge, and then the battery capacity tanked seemingly overnight. I tested it a few days ago and after a full charge it was depleted in less than 4 hours. I've gone through the community recommendations and turned off auto-sync as well as HR tracking.
09:36
10:54
06-06-2018
09:36
10:54
Hi there @ChrisHilty. Good to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear that the battery on your Blaze seems to be draining faster than it should. Thanks a lot for taking the time to follow the recommendations.
In this situation, I've gone ahead and escalated your case to the Support Team for them to take a deeper look and hopefully we'll have you back on track soon. Keep an eye on your inbox for more instructions and if you need anything else, let me know!
Best Answer06-06-2018 10:15
06-06-2018 10:15
I have the same problem. A few days ago, suddenly the battery life has tanked... It used to last 4 to 5 days with my normal use for many many months, but since a few days ago, the charge does not last a day. HELP!!!
