02-26-2016 20:19 - last edited on 02-27-2016 10:52 by SunsetRunner
I just got my Blaze. The set up was fine until I started charging it. The battery icon never showed on the screen. I also have a Charge and it charged using the same computer an hour before. Anyone have a problem charging the Blaze?
Moderator edit: title for clarity.
12-29-2016
20:39
12:42
SantiR
12-29-2016
20:39
12:42
SantiR
I have already downloaded it in my mobile but it is showing low battery before updating it
Moderator Edit: Format
12-30-2016 20:10
12-30-2016 20:10
01-01-2017 02:17
01-01-2017 02:17
Thanks for this. I was having same problem. The device is inserted in the cradle and is closed so I assumed this would hold it in the correct position. I opened again and pushed until I heard the click then closed the cradle lid. This time I did see the green lines across the screen. I think it is a very poor design as the cradle lid will close even if it is not in the correct position and I don't think it should do this as it's too easy to not do it correctly as so many of us have had problems.
01-01-2017 10:03 - edited 01-02-2017 04:27
I got a Blaze for Christmas. I can't complete setup because the charge is too low. It won't charge. I never get the "battery." It just has the logo and fitbit.com/setup one the screen. I followed the instructions for charging and even tried resetting. Any other suggestions?
01-01-2017 12:46
01-01-2017 12:46
That's correct @mariebart the tracker will not show a charging icon until it is setup.. You will feel a bib ration tha tells you that it is charging.
01-02-2017 04:26
01-02-2017 04:26
Success! It would be helpful to know that we won't see the "battery" before it's set up and that it may take a long time to charge the first time. I left mine overnight and was able to set it up in the morning.
01-02-2017 04:56
01-02-2017 04:56
01-02-2017 09:00
01-02-2017 09:00
I am having the same problem. Very disappointed with this product
01-02-2017 09:53 - edited 01-02-2017 09:54
Most people fiind that the charge2 clicks firmly onto it's charfer, and of the three I have helped setup a 30 minute charge on a phone charger was enough to get it up and running.
As for setting up and doing the update 6 minutes was the fastest 11 minutes was the longest.
I'm sorry @Kmoore0863 I'm not sure which of the above problems your is about,
01-02-2017 19:21
01-02-2017 19:21
Count me in the same camp. No charging screen, etc. Have it hooked up to the pc and get the same message as I do from my phone - not enough battery. The PC says battery is nearly empty and doesn't say it is charging (would it?). It doesn't vibrate when I put it in the cradle but the PC does chime when I open and close it which leads me to believe I have good contact.
I'm just going to be patient overnight. I'm mainly posting to stay simply hooking it up to the PC doesn't mean it will update either. Perhaps that means I don't have a solid connection though. How is one to know?
01-07-2017 20:42
01-07-2017 20:42
I do have the same problem, my fitbit blaze is not charging. I download everything was ok until I was of of charge, Went to charged and nothing happen, the red light in the battery is the same than yesterday very low
01-09-2017 06:38
01-09-2017 06:38
Updating my post... It did not charge overnight, but I used my cars USB outlet when I drove to work the next morning and got enough of a charge to do the update. No issues since.
01-09-2017 11:22
01-09-2017 11:22
I just received my fitbit and tried to update but it says it needs to be charged before it can update. If it can not charge in the update screen before its updated, what am i supposed to do?
01-19-2017 15:33
01-19-2017 15:33
Did you get a resolution for your problem
01-19-2017 15:43
01-19-2017 15:43
01-19-2017 15:50
01-19-2017 15:50
01-19-2017 16:04
01-19-2017 16:04
Thank you Marie
Did you charge it overnight with the setup symbol on the display or did it show the charging symbol? (My fitbit only shows the setup screen)
01-20-2017 05:36
01-20-2017 05:36
01-20-2017 05:43
01-20-2017 05:43
Yes there will not be a charging symbol until the unit is setup.
However there will be a slight vibration when plugging the unit into power. This vibration is telling yo that the ynit is charging.
30 -60 minutes on the charger is more tyan enough, the other option is to set it up while the unit is still in it's charger.
02-12-2017 17:54
02-12-2017 17:54
I reached out, sent mine back and having the same problem with the replacement. Sounds like a major flaw
