I had Fitbit Alta for few months and then got Fitbit Blaze yesterday 3/28. Was all excited and plugged it in for charging it doesn't charge, very disappointed. Tried troubleshooting techniques no use so got on to customer service and they are sending a replacement. I saw several people reported the same issue on the community forum why the company is not taking any action to check and send a working product.
05:08
08:42
03-30-2017
05:08
08:42
A warm welcome to the Community @VVK thanks for troubleshooting this inconvenience by yourself and for your feedback. I am glad to hear that you will be receiving a new Blaze, at the moment of receiving, you just need to do the following to set it up from your Fitbit app:
Catch you later. ![]()
Best AnswerThank you for responding.
The Fitbit sent me replacement but that also had the same issue. I was not able to setup without charging but wouldn't charge through Laptop USB, tried multiple laptops and different ports. However I figured out it could charge by plugging into iPhone wall adapter.
04:09
08:42
04-12-2017
04:09
08:42
It's great to see you around @CHICKEY17 and @VVK thanks for the information.
If your trackers are not charging, I recommend following the instructions provided in this post.
I hope this helps, let me know the outcome. ![]()
