02-11-2019
23:18
12:32
FerdinandFitbit
02-11-2019
23:18
12:32
FerdinandFitbit
My Fitbit just ceased working. All I got is dit’s on the screen that look like little pac men. Fitbit is only 14 months old. It is s blaze.
Moderator edit: Updated title for clarity
Best Answer02-12-2019 12:31
02-12-2019 12:31
Hi there @Veeno, welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that you're having problems with your Fitbit Blaze display behaving like this.
I'd like to help you out.
My first recommendation would be to give your Blaze a quick restart and see how it goes. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
After that, see if your tracker works fine. If it doesn't, let me know and I'll be happy to help you out with this.
07-22-2019 10:55
07-22-2019 10:55
This is exactly what's happening with mine...vibrates every 10 seconds or so. Will not reset
Best Answer07-22-2019 10:59
07-22-2019 10:59
Best Answer07-22-2019 11:38
07-22-2019 11:38
Best Answer07-22-2019 11:53
07-22-2019 11:53
Best Answer07-22-2019 22:28
07-22-2019 22:28
