11-10-2016 16:11
11-10-2016 16:11
My husband let his FITBIT Blaze battery totally run out, and now it will not charge. I know the charger works fine, because when I put mine in, it displays as it should. Suggestions??? Cannot turn off to reset/reboot, because I cannot turn it on!
11-10-2016 16:34
11-10-2016 16:34
@tjkfree3 How long have you tried to charge it? If you have left it for a while, and still not responding, you may need to contact support to have them assist you further.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
11-10-2016 17:01
11-10-2016 17:01
11-11-2016 04:39
11-11-2016 04:39
Welcome to the Forums @tjkfree3. @Kmransom123 and @Rich_Laue thanks for stopping by and the tips provided. If the tracker is not responding, as mentioned you can leave it a while in the charging cable and also try the restart process.
I hope this helps, let me know the outcome.
