03-27-2020 04:34
03-27-2020 04:34
Please help. My Fitbit Blaze will not stay on. If you hold in the 2 buttons to restart the device, it will show the logo but then turn off. If you put it on the charger, it does not display anything to indicate it is. I have made sure all contacts clean. What else can I do?
03-28-2020 06:14
03-28-2020 06:14
Hi.
I'm having the same problem. Did you manage to fix it?
Eva
Best Answer03-28-2020 07:00
03-28-2020 07:00
Best Answer03-28-2020 08:50
03-28-2020 08:50
Maybe thay will answer on Monday! Hopefully 🙈
Best Answer03-29-2020 16:09
03-29-2020 16:09
I too have been having the same issues... My Blaze is fully charged too... Wonder if they are trying to force us to upgrade... My Blaze is 3.5 years old
03-30-2020 21:04
03-30-2020 21:04
mine just turned off suddenly too
Best Answer03-30-2020 21:19
03-30-2020 21:19
I left my blaze plugged in for 20 min while I was reading the troubleshooting. I just read something about restarting the blaze by pressing the back button (left single button) along with the bottom button (right side 2nd button on the bottom) for 10 seconds. It turned on and it showed low battery now and is showing that it is charging (it wasn't showing anything before - black screen). I am hoping that did it!
Best Answer03-31-2020 03:46
03-31-2020 03:46
Best Answer03-31-2020 07:40
03-31-2020 07:40
I am having similar issues. Put it in charger until fully charged, or so it shows, then put it back in band and wear for maybe 2 hrs before it's dead again.
04-02-2020 08:29
04-02-2020 08:29
Mine will not take the reset command either and just displays the logo. I even connected it to my laptop but that too does nothing.
