03-02-2016 10:31
03-02-2016 10:31
08-25-2016 05:06
08-25-2016 05:06
Hello @Jack_Yaz, @SeattleSUP and @Rich_Laue! @SeattleSUP thanks for sharing your experience. @Jack_Yaz is your app up to date the latest version (2.32) was released on August 22, 2016? @Rich_Laue thanks for your cooperation! 😉
I'll be around if you have any questions! 😉
It is health that is real wealth and not pieces of silver and gold! Share your story!
08-25-2016 05:16
08-25-2016 05:16
11-15-2016 09:58
11-15-2016 09:58
11-15-2016 10:00
11-15-2016 10:00
11-15-2016 11:52
11-15-2016 11:52
Hi there @Akadawgfan. Good to see you in the Community! 🙂
What phone do you have that should be compatible but doesn't sync? When it comes to iPhone, all models should be compatible starting from the 4S. Are you also having problems with an iPhone model? What error are you experiencing?
11-30-2016 03:53
11-30-2016 03:53
I just received my Blaze.My phone is a Samsung Galaxy 5 mini. It will not sync. I have tried all of the suggestions that were on this page.
11-30-2016 08:14
11-30-2016 08:14
Hey there @joreeder. Good to see you in the Community! 🙂
It's strange that your phone is not syncing with your Blaze as it should be compatible. It's in the list of compatible devices.
Do you see any type of error message or have you already been able to set it up?
11-30-2016 08:31
11-30-2016 08:31
11-30-2016 08:41
11-30-2016 08:41
Huh, interesting to hear it was the tracker itself. I'm glad that after having it replaced it's all working fine @markdreid! 🙂
Good to see you around!
11-30-2016 09:20
11-30-2016 09:20
I, too, am having trouble getting my Blaze to show text messages and phone calls. I don't care about getting the music control to work, but I do want the text and phone calls to show. I have done everything suggested and nothing works.
12-09-2016 08:24
12-09-2016 08:24
Also here, in Belgium the same BIG problem. Blaze doesn't sync with Samsung S 5.
frustrating !
12-09-2016 09:49
12-09-2016 09:49
I'm also facing the same problem. Not able to sync with my Samsung Note 3. I have fitbit connect setup on my mac also. FItbit connect is not able to detect the internet. I think it is most likely the problem with internet provider. It is extremely frustating. Each time i've to think of a workaround to to do sync.
12-11-2016 03:53
12-11-2016 03:53
A warm welcome to the Community @Josmet and @ankit8364. If your trackers are not syncing with your Android devices, I recommend following our syncing troubleshot. After these steps your trackers should sync without an inconvenience.
Let me know the outcome.
02-15-2017 20:29
02-15-2017 20:29
After 2 hours on the phone with Fitbit support, still not able to figure out why my Samsung S4 won't sync with Blaze. After some digging, was able to get it to work by clearing cache and data on Bluetooth app (see link below) and then setting up Blaze through the Fitbit app. Don't know how long it will keep working. Fingers crossed.
http://www.smartmobilephonesolutions.com/content/how-to-fix-bluetooth-android-cell-phone
02-16-2017 07:34 - edited 02-16-2017 07:34
Hi there @Stankdog. Welcome to the Community Forums! 🙂
I'm glad to hear that it's all working for now and hopefully it stays that way. Fingers crossed here as well!.
Let me know if you need more help!
03-17-2017 11:52
03-17-2017 11:52
Add me to the group.....I have been trying for months to get the sync to work. I keep retrying and it won't stay connected. I have to force it to sync to even update my stats. I REALLY like the fitbit itself and the look and feel. It just does not do what is promised.
03-18-2017 07:10
03-18-2017 07:10
11-06-2017 11:04
11-06-2017 11:04
I've done it all SEVERAL times, now it won't even set up. It says it's connected, but when I go to sink the app says it can not find the tracker, extremely frustrated.
02-28-2018 20:59
02-28-2018 20:59
I have a Samsung galaxy s7 edge. I can't get my fitbit blaze to sync at all but it will sync perfectly with my iPad. I have tried restarting my Bluetooth and restarted my phone but it still will not sync. Please help.
01-06-2019 13:07
01-06-2019 13:07
Still having this issue after a year! So annoying thinking of getting a Garmin now
