03-07-2018
01:22
10:21
FerdinandFitbit
03-07-2018
01:22
10:21
FerdinandFitbit
My fit bit blase Screen is blank and won't come on. It was fully charged when it went out. Please help.
03-07-2018 10:15
03-07-2018 10:15
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help Contact Support.
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
03-07-2018
10:20
06:54
03-07-2018
10:20
06:54
Welcome to the Fitbit Community Forums @Rochelle2! 🙂
I'm sorry you're having problems with your tracker not turning on or responding. As @WendyB said, you can try to restart your tracker. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
If that doesn't help, let me know and I'll be happy to provide further assistance.
07-21-2018 05:13
07-21-2018 05:13
I have a fitbit blaze. My fitbit wont turn on. I tried to turn it on this morning and the greenlight just flickered. I tried to charge it and still it wont power up. This has never been wet and never dropped. I dont have the box now..can i have this replaced?thanks.
07-22-2018
07:01
06:54
07-22-2018
07:01
06:54
Welcome to the Forums @Jonaezo! 🙂
I'm very sorry to hear that your Blaze is not turning on and thanks a lot for what you've already tried to get it to work.
Now, have you tried by any chance to restart it? If not, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. If it doesn't come back on after that and if after putting it on the charger it still doesn't light up or doesn't even sync, please, let me know and I'll be happy to help you out!
07-22-2018 15:34
07-22-2018 15:34
Hi ferdinand
Yeah ive tried that step since ive did a little research online. Thanks.
07-24-2018
07:19
06:55
07-24-2018
07:19
06:55
Thanks for getting back @Jonaezo and for trying to restart your tracker.
Since that hasn't worked, I've gone ahead and escalated your case to the Support Team for them to help you out with this and get you back on track. Keep an eye on your inbox for more instructions and if you need anything else, I'm always around! 🙂
08-11-2018 09:49
08-11-2018 09:49
Has there been a resolution to this issue? I purchased a Blaze for my mom recently and, similar to others, it's never been wet oror dropped. In the charger, it turns on and shows that it's fully charged, but will not come on when off the charger. The reset doesn't do anything.
08-12-2018 21:41
08-12-2018 21:41
My Fitbit quit working this morning after charging all night for no apparent reason?
Thanks!
09-13-2018 22:02
09-13-2018 22:02
i have tried holding down the left and lower right button and i still has not turned on. What can i do now?
09-14-2018 04:01
09-14-2018 04:01
My blaze will not turn on. The heartrate monitor has not been working and it's been losing its charge within 9 hours. I done a reset. I've cleaned the prongs. I've updated my app settings.
What next? I can't find a cust service phone number.
11-21-2018 06:59
11-21-2018 06:59
Did you get resolution on this? I have the same issue and tried the restart 🙁
12-21-2018 14:52
12-21-2018 14:52
I have tried to restart my Fitbit blaze with the buttons and nothing is working. There is no green flashing light, the screen is blank, but it turns on while on charger
12-21-2018 15:52
12-21-2018 15:52
Mine never resolved. Fortunately was in warranty so was replaced by Fitbit.
06-01-2019 10:19
06-01-2019 10:19
My blaze will not turn on either. When I plug it in to charge, it lights up and says it is fully charged, but when I unplug it... nothing. I have tried restarting and got nothing as wel .
