03-05-2016 16:54
03-05-2016 16:54
I have just received the latest Fitbit Blaze. Have charged it for 24+ hours (but never saw a green battery or any indication it was charging). Have download the app onto my PC, mobile and iPad. CANT TURN THE FRIGGEN THING ON!~... the screen wont come off fitbit.com/setup. Have held all three buttons down simultaneously, swiped the screen every which way but still no joy. Have emailed support 3 days ago and still no respons 😞
03-17-2017 17:22
03-17-2017 17:22
It's great to have you here @OlyveOyle! The fitbit.com/setup will only show when your Blaze hasn't been paired to any account. In this case, I would like you to make sure that you're log into your account and that you've followed this set up procedure.
Note: Once your Blaze is properly linked to your account, it should show a clock face as the main screen.
Keep me posted.
03-17-2017 20:25
03-17-2017 20:25
Thanks for your reply.
It is paired and I can see it's syncing. It's telling me the battery is medium and then later on today it told me the battery was low (no step count though). But it the face of the watch still says set up.
Best Answer03-17-2017 23:57
03-17-2017 23:57
I have the same problem. I received my new Fitbit Blaze today and plugged it in to my computer to charge. We started setting it up with my iphone, while plugged in. It said not enough charge to update in the set up please plug it in. It was plugged in, so I left it for two hours. When I came back - same thing. It still says Fit Bit set up. I tried restarting it. Comes back to the Fitbit setup screen. Is it maybe not charging? Or have I just not left it long enough for first time use. Blutooth says Blaze is connected on my phone.
Best Answer03-18-2017 06:33
03-18-2017 06:33
I bought the fitbit blaze, made the updates and the battery is fully charged. When its plugged in its on, but when I try to put it on the wristband nothing happens. When its connected its sync but when I take it off its blank...do I have a defective one?
Best Answer03-22-2017 18:58
03-22-2017 18:58
I figured out my problem! So I had updated the actual tracker but I needed to update the app on my phone. As soon as I did that it worked no problem.
Now I just wish it would sync consistently. Sometimes it does sometimes it says it can't find my tracker. I make sure there are no other bluetooth's on in my house and it's still a problem. I never had any issues with my Charge HR 😞 I wish my Charge HR didn't break. I loved that tracker. I'm starting to feel like I should have stuck with another Charge.
Best Answer03-22-2017 22:30
03-22-2017 22:30
Best Answer04-08-2017 15:03
04-08-2017 15:03
My blaze turned off by itself amd won't turn on anymore. When its charging there is nothing on the screen....is it dead??
Best Answer04-10-2017 18:39
04-10-2017 18:39
@OlyveOyle Thanks for letting me know that it was resolved. I've shared your information with Customer Support so they can further assist you.
Hey there @juliebye! Thanks for the troubleshoot that you've done. Please make sure that you're setting up the Blaze from the Fitbit app and not using your phone's Bluetooth. I would like you to double check you're following this set up steps. Additionally, most of the time you receive this message in your computer, it's because the device hasn't been installed properly in your computer or it hasn't been detected at all.
Welcome to the Community @Iarias1234. I would like you to restart your Blaze, so the display issue can be fixed. Have you properly charged your tracker?
It's great to have you here @Kapterian. Please restart your tracker so it the display can start working again. Are you charging your tracker properly?
Keep me posted.
04-11-2017 10:18
04-11-2017 10:18
I'm having the same issue. It's stick on the setup screen. It is synced to my phone and although I have charged it for hours, I never saw the charge icon and the app says the battery is empty so I can't get it on. Please help!
Best Answer04-13-2017 12:15
04-13-2017 12:15
Welcome to the Community @NiaLotus! If you haven't set it up yet, then the battery level won't update in the app because it needs to sync in order to transfer the information. I would like you to try this set up troubleshoot, restart your tracker and make sure you're charging your tracker properly.
Hope this helps.
04-13-2017 17:26
04-13-2017 17:26
05-30-2017 04:39
05-30-2017 04:39
I have tried this and it still doesn't work 😞
Best Answer05-30-2017 10:36 - edited 05-30-2017 10:40
Hey there @ReneeRLevesque! Thanks for letting me know that you restarted your tracker. I've shared your post with Customer Support, they should reply to you within the following days.
Thanks for your understanding. ![]()
07-20-2017 11:05
07-20-2017 11:05
The face of my Blaze is totally black. It had the setup screen on during most of the charging, but now it's just black. If you have any advice I would appreciate it. Thank you.
Best Answer07-20-2017 11:08
07-20-2017 11:08
I am having the exact same problem that you are describing. I'm at a loss at the what to try next.
Best Answer07-24-2017 05:10
07-24-2017 05:10
Welcome to the Community @hollejam! I would like you to confirm that you've restarted your tracker. Are you still not getting anything in your display? Are you properly charging your Blaze?
Keep me posted! ![]()
07-27-2017 21:23
07-27-2017 21:23
Best Answer08-23-2017 01:15
08-23-2017 01:15
I just bought my Fitbit blaze and it has been charging over 2hr. While in the charging station I can see the screen logo on but that's that. The moment I take it out from the charging station the screen is dead. Trying pressing the left button and the lower right at the same time and still nothing.
I figure I try here but chances are I will return this and go for the apple.
Best Answer08-24-2017 11:24 - edited 08-24-2017 11:25
It's great to have you here @milosstevan! Thanks for the details that you've mentioned. Currently, I would like you to make sure that you restarted your tracker properly. Also, double check you're charging your tracker correctly; you can also try with another USB ports.
Also, I've sent you a PM with further instructions.
Hope this helps! Keep me posted.
08-24-2017 16:43
08-24-2017 16:43
