03-15-2017 11:41
03-15-2017 11:41
My Fitbit blaze will not track my heart rate and green lights are not working.
Best Answer08-20-2017 04:42
08-20-2017 04:42
Hey there @sean.thiemann and @Lllampert. I just would like to know if the instructions provided by our friend @FerdinandFitbit worked? Are you still having inconveniences with the information that your trackers are registering?
Hope to hear from you soon. ![]()
Best Answer08-20-2017 07:29
08-20-2017 07:29
My fit bit is dead. New one on the way.
08-20-2017 08:49
08-20-2017 08:49
Best Answer08-20-2017 12:30
08-20-2017 12:30
Just wanted to say thank you. I was having the same issue, but I just read the response and now my blaze is tracking my heart rate.
Best Answer08-20-2017 13:04 - edited 08-20-2017 13:06
@sean.thiemann @Lllampert,Hey guys, great to see you around and I'm happy to hear that you're getting your replacements! Hope to see you back on track soon! 😄
@memefit That's great to hear! 😄 Glad that this got you back on track. Let us know if you need anything else at all!
Best Answer10-17-2017 13:28
10-17-2017 13:28
My Fitbit won't track my heart rate. lights still work, checked the app and the tracker to make sure heart rate is switched on, it is. Even tried to switch wrists, still nothing. Reset the tracker several times
01-10-2018 10:17
01-10-2018 10:17
this action worked. Thank you for answering this question.....:-)
05-18-2018 20:41
05-18-2018 20:41
Hello I’ve had my Fitbit for about 4 months now and up until 5 days ago it worked perfectly I’ve reset it at least 10 times set it up as a new device twice and nothing works the lights are flashing but I get the - - for heart rate so it’s not able to track sleep either. I’ve also cleaned the back using alcohol please help.
Best Answer09-24-2018 19:25
09-24-2018 19:25
My Fitbit blaze will not monitor my heart rate. I have tried restarting my device several times. No change. Please help
Best Answer09-25-2018 04:33
09-25-2018 04:33
Best Answer08-02-2019 10:38
08-02-2019 10:38
I’m having the same issue. The green light is not working and my heart rate indicator shows it is completed all the time. I’ve tried resetting it and nothing has changed.
Best Answer08-02-2019 10:52
08-02-2019 10:52
