08-18-2022 05:24
08-18-2022 05:24
My Blaze stopped charging all of a sudden, with a blank display even on the charger . But I was able to make it charge again by cleaning the gold pins in the charger and on the back of the watch with rubbing alcohol and a q-tip. Then, I kept hitting the back of the charger with my finger a few times, then bingo. It does charge now without any issues. Give it a shot, it might work for you.
Upon fixing the charging problem,I also noticed that it was getting really hot during and after charging it. For some reason, Fitbit’s recent firmware update forces the heart rate monitor to stay on, in full blast, which leads me to believe that Fitbit is doing this on purpose in order to drain the battery quickly; so we can buy a newer watch.
To fix the heating issue, turn off the heart rate monitor before you put it on the charger, and keep checking it every now and then because it does turn on again by itself while on the charger. If it does, you will need to go to touch the screen-scroll to settings-make sure heart rate monitor is off- then scroll down and tap on Shutdown Device. Wait a couple of mins then turn it on. Hope this works for you as well.
Shame on Fitbit for doing this, Apple also did something similar with older iPhones for a while until people realized what’s going on. Soon enough this will backfire on Fitbit
Best Answer09-18-2022 09:33
09-18-2022 09:33
@Infoseek The Blaze is an older model and was discontinued in 2018. Rechargeable batteries have a lifespan (reported to be 3-5 years when you take good care of them). Some of the issues you describe are things we all see when a rechargeable battery gets to its end of life. Any time a battery gets hot in the charger, you should remove it from the charger and stop using the device.
You mention a firmware update. Fitbit rarely releases firmware updates two years after a model is discontinued, so I'm not sure what update you could have received. BTW, my husband wears a Blaze and hasn't received a firmware update recently.
I honestly don't think there is any Fitbit conspiracy to sabotage your Blaze.
Laurie | Maryland
