08-01-2018
17:35
04:59
AlejandraFitbit
08-01-2018
17:35
04:59
AlejandraFitbit
Got new Bluetooth earbuds for my run. Disappointed to discover that GPS pairing between Blaze and iPhone drops between 1km and 2km into my run without notice. When I look at my watch, it looks like the run was abruptly cancelled. I’m listening to music using Spotify.
08-02-2018 05:00
08-02-2018 05:00
Hey @Kenny512, great to see you here.
If your phone is managing multiple Bluetooth connections simultaneously:
These interruptions are typically caused by operating system and Bluetooth limitations. It's also possible that an app on your phone is causing the issue.
If you have an Android phone, try these steps:
The API used in these apps makes it difficult for Fitbit to communicate reliably with your phone. Ford provides a list of apps but note that other companies may use the API as well.
Let me know the outcome.
