02-02-2017
08:35
18:39
DavideFitbit
02-02-2017
08:35
18:39
DavideFitbit
sorry i stated i had a blaze but it is actually a surge and the golf setting doesn't appear to work as i only get a stop watch running.
02-02-2017 10:51
02-02-2017 10:51
Hi, @Billybob361, I think that is probably correct. Have you tried it? When you start the golf workout it should first search for a satellite and then as soon as it is found, begin the stop watch. At the end of your round you need to stop the activity and then when you sync you should have a map and details of your heart rate, pace, and dostance.
02-02-2017 11:50
02-02-2017 11:50
Hi Julia, thanks for your help, but surely that's what the surge does anyway. I will give another go next game. Thanks again, Bill.
02-02-2017 11:57
02-02-2017 11:57
Exactly! That's what the Surge does. You press the button, it finds the satellites, it starts the stop watch, you sync, and your data is there.
I agree that your best bet is to try next round. And when you get a stopwatch. carry on!
