02-25-2020 11:01
02-25-2020 11:01
Within the last week, my Blaze has stopped working. I am having daily and it reflects that it is fully charge, but within hours it shows dead. Has anyone else had this problem? Do I need a new charger or should change to another device? I have never had this to happen before and recently purchased Fitbit Blaze less than a year ago.
02-25-2020 11:50
02-25-2020 11:50
Hi
i have started to have this same issue over last week or so. Has anyone give u any suggestions yet? I’m not hoping it’s a way to try to get us to upgrade!!
02-26-2020 04:07
02-26-2020 04:07
Hi, I experience the same issue as do a couple of friends (they have different trackers than I do, but still the same experience). I have tried everything that FitBit suggests to fix the problem but still no solution. I find it suspicious that it appears to all be within a similar timeline. Possibly a FitBit firmware issue but I also hope that this isn't their strategy to get people to upgrade
02-26-2020 06:07
02-26-2020 06:07
Have not received any suggestions.
Best Answer02-26-2020 06:08
02-26-2020 06:08
It does sound like they want us to upgrade.
03-02-2020 01:51
03-02-2020 01:51
My blaze has suddenly started doing the same thing and it’s just over a year old. This is my second watch and the same thing happened with that one too after 18 months. I didn’t receive any useful help then either. I will not be buying any further products from them in the future. Very dissapointed
03-08-2020 08:37
03-08-2020 08:37
I am experiencing the same issues. It went from working perfectly to being a dud within a month. After the most recent update is when I started having issues.
03-09-2020 07:41
03-09-2020 07:41
I tried all the suggestions provided by Fitbit and nothing worked. My frustration is that at the end of all the trouble-shooting, I was essentially told that I was checking my stats/syncing too often and that was draining the battery. My solution was to place my Fitbit into a desk drawer, forget about it and just use an old fashioned wrist watch. So far no battery issues!
