05-10-2016 06:35
05-10-2016 06:35
Best Answer05-10-2016 08:55
05-10-2016 08:55
Have you tried resetting the fitbit. I have noticed that with this last update some things don't work exactly as they used to. Resetting the watch can fix some of those things.
Best Answer05-10-2016 11:03
05-10-2016 11:03
My heart rate monitor on my 1 week old Blaze also stopped working yesterday. No response to reset or changing settings from auto to on
Best Answer05-10-2016 15:18
05-10-2016 15:18
Best Answer05-10-2016 17:15
05-10-2016 17:15
05-11-2016 03:28
05-11-2016 03:28
There are a couple of ways to restart the Blaze, a hard reset, andthe Shutdown command in the settings menu. Please try both.
When saying the Heart Rate doesn't work, are the lights flashing, or is the HR just not displaying?
Best Answer05-11-2016 08:42
05-11-2016 08:42
Best Answer05-11-2016 08:44
05-11-2016 08:44
Have you called customer support? Have them trouble shoot it. If they can't get it fixed it may be a defective tracker and they will send you another. Good luck.
Best Answer05-12-2016 08:40
05-12-2016 08:40
Best Answer05-12-2016 08:48
05-12-2016 08:48
Hmm. If they can't trouble shoot it I don't see why they would need you to contact engineering. I'd call again and insist on your device being faulty and see where that gets you.
Does the green LED light come on at all to try and see your heart rate? Have you checked in your dashboard to make sure the heart rate wasn't being recorded and you just aren't seeing it on the watchface for some reason?
Best Answer05-12-2016 09:54
05-12-2016 09:54
Best Answer10-19-2017 14:19
10-19-2017 14:19
My Blaze had this problem that started either yesterday or this morning. It was showing "--" for heartrate and the green lights were not flashing. I fixed by doing a reset following instructions at: http://help.fitbit.com/articles/en_US/Help_article/1186
