01-28-2018
02:06
08:45
FerdinandFitbit
01-28-2018
02:06
08:45
FerdinandFitbit
My Fitbit Blaze has suddenly stopped registering heartbeat or sleep for the last 3 days. During the day when active it has taken some intermittent heartbeat readings but these are interrupted and not continuous. Additionally last night I had fully charged it before going to bed and in the morning the power was completely drained - a charge normally lasts 3/4 days. Anyone have any help here - has the unit just gone wrong ?
01-30-2018
08:44
08:49
01-30-2018
08:44
08:49
Hi there @Wombledon. Great to see you in the Fitbit Community Forums! 🙂
I'm sorry you're having problems with your Blaze not showing your heart rate, missing sleep and the battery not lasting as it should. Seems like a bad combo ![]()
Now, when it comes to your sleep not being recognized properly, if your heart rate is not working good, sleep will not be recorded accurately, so these two things go by the hand. About the battery, that sounds really strange but it could also have something to do with the overall issue. Have you already tried to restart your tracker by any chance? If not, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. After restarting your tracker, see if the heart rate monitors on the back of your tracker are working by having the green lights blinking.
Then, about the battery, I can recommend putting it to charge and once it's fully charged, take it off the cradle and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
Please let me know if you need more help with this!
