08-24-2017 11:06
08-24-2017 11:06
Hi,
My heart rate monitor has stopped working for the past week.
The green lights (both of them) are flashing.
When I have the heart rate on Auto, all I get are the double bars --. When I switch the heart rate monitor to ON I get a heart rate. It's significantly higher than what it should be though.. It was reading 114 when I counted out 74.
I have cleaned the sensor on the back. I have rebooted as well as re-sync'd it. Turned the monitor off/on and back to auto.
The lights seem to flash fast when I switch it to ON but stay slow and steady when it's on Auto even when I take it off my arm.
Any ideas? Any recent firmware updates I'm missing?
Thanks
--Bill
Best Answer08-24-2017 11:32
08-24-2017 11:32
Hey @BillBlazer! Welcome to the Fitbit Community! Try removing your Blaze from you Fitbit account and then setting it up like new. Let me know if that helps at all!
Quick Note:
Make sure you Sync your Blaze before you remove it or else all un-synced will be lost.
Michael Groff | CO, USA
Fitness isn’t being better than someone else, it’s being better than you used to be!
Best Answer08-24-2017 12:29
08-24-2017 12:29
Best Answer08-25-2017 05:58
08-25-2017 05:58
Same exact issues here with the heart rate auto/on. I contacted support, but they are just checking into if it is under warranty for a replacement. I feel like this has to be some sort of bug, since others are experiencing it.
Best Answer08-27-2017 05:03
08-27-2017 05:03
It's great to welcome you @BillBlazer, @Beyerkel good to see you here and @RunningFreak thanks for stopping by.
If you are having issues with your heart rate information, I recommend taking a look at this post, where you will be able to see some things that might be affecting this reading and some tips to improve it.
I hope this helps, let me know the outcome. ![]()
Best Answer08-29-2017 05:11
08-29-2017 05:11
Best Answer08-29-2017 14:08
08-29-2017 14:08
It is completely dead now won't keep a charge. They are sending a new one but haven't heard anything since Friday. How long will that take?
