10-13-2017 22:43
10-13-2017 22:43
Hi all anyone know what to do when the green light stops working and then doesn’t show any heart rate ? Many thanks Chris
Best Answer10-14-2017 15:17
10-14-2017 15:17
It's great to have you here @Chrisoreilly08! I would like you to double check that your heart rate settings are set to on, so it can show you the heart rate information; check the instructions here.
If after performing the steps above, the lights aren't working. Please restart your tracker.
Hope this helps! Keep me posted. ![]()
Best Answer10-14-2017 16:33
10-14-2017 16:33
I'm havig the same issue. I've tried changing the HR monitor from auto to on (and back), restarting by going through the shutdown option, as well as restarting the tracker. Nothing works. Suggestions?
10-16-2017 06:16
10-16-2017 06:16
Hey there @JDeForrest! Thanks for the troubleshooting that you've done. I've sent you a PM with further instructions.
Hope this helps!
10-16-2017 06:28
10-16-2017 06:28
Hi 👋🏻 I’ve got it working now I deleted the app on my phone then reset it and boom green light flashing and heart ❣ rate monitor up and running again hope this works for you.good luck many thanks Chris 😊👍
10-17-2017 14:42
10-17-2017 14:42
Best Answer10-18-2017 08:38
10-18-2017 08:38
Best Answer10-18-2017 12:17 - edited 10-18-2017 13:03
Can you share the troubleshooting instructions for the rest of us that have never had the heart monitor work correctly after 10 months. When I am on treadmill running 6mph it still shows 84bpm when I measure it on neck at over 100. Have tried all different settings and positions on wrist and it is never consistent or accurate.
Thanks
Best Answer10-18-2017 18:03
10-18-2017 18:03
