07-31-2016 04:04
07-31-2016 04:04
Best Answer07-31-2016 05:41
07-31-2016 05:41
Set your Stride Length
https://help.fitbit.com/articles/en_US/Help_article/How-do-I-measure-and-adjust-my-stride-length/
Wendy | CA | Moto G6 Android
07-31-2016 05:41
07-31-2016 05:41
07-31-2016 06:05
07-31-2016 06:05
Best Answer07-31-2016 08:43
07-31-2016 08:43
Have you done a successful sync since changing the height, if not the tracker still thinks your very small, and issues that for your stride calculations.
A note on auto stride, it is based on the average person with the same height, age, gender, etc.. This basically means it will only be perfect for a few, but should be close for many.
Best Answer07-31-2016 09:22
07-31-2016 09:22
Best Answer07-31-2016 14:15
07-31-2016 14:15
Have you checked and set your stride?
Best Answer07-31-2016 21:11
07-31-2016 21:11
06:29
09:44
08-16-2016
06:29
09:44
Hi @naseema. Good to see you around! 🙂
Have you tried to set up your tracker as a new device?
You can do this by going to the Account section on your app and here, tap on the option that says "Set up a new Fitbit device". Once you are there, just follow the on-screen instructions and after it's paired again, try it out and see how it goes!
Let me know if this worked for you.
Best Answer08-16-2016 06:31
08-16-2016 06:31
