09-30-2017 07:06
09-30-2017 07:06
Just change to a Samsung 8+...no luck on getting my notifications!! Have tried updating uninstall pairing....I have chosen blaze classic...input device is off, is this correct?
Any suggestions...
09-30-2017 09:19
09-30-2017 09:19
No, classic bluetooth is for music controls. Make sure bluetooth is active on your phone. Then going into the app and the settings for the Blaze and make sure you have enabled all the notifications that you want and chosen which app you use (Google Dialer, Samsung messaging, etc.)
