10-11-2016 10:36
10-11-2016 10:36
Best Answer10-11-2016 13:11
10-11-2016 13:11
Go to the web dashboard. Elevation is not always accurate, and its not sync'd to your ride timeline. Fitbit hasn't done anything to improve things in the almost 2 years since introducing the Surge and bike elevation tracking. Lame.
Best Answer10-11-2016 13:48
10-11-2016 13:48
Best Answer10-12-2016 05:48 - edited 10-12-2016 05:48
Hi there @Nick7474. Good to see you in the Community!
As @bbarrera says, the elevation gain at the moment shows only in the web dashboard and is not hooked to the speed/HR/calories data. When recording your bike ride from your exercises on your Blaze, you will see it in a small box at the low right corner of the map as you can see below:
Now, if you let SmartTrack (the feature that auto recognizes your activity) to record your bike ride, elevation gain will not appear on your summary.
Anything else you may need, let us know!
